PB ZX6R J2 Suspension guide?
Started by DaveH, May 17, 2021, 03:02:23 PM
DaveH
Does anyone have the link to the aforementioned Performance Bikes suspension setups for the 2001(ish) 6R?
Used this as a base setting for my first one and got on pretty will with it but the only think I can remember is jacking the back up by 8mm. Have played about with the settings but would be interesting to see what they had.
Sure I have it on an old hard drive.
Will have a look tonight.
have you had a look through the old mcnninja archive?
had a quick look and are a few topics referring to J1/2 settings
BMW R nine T
DaveH
Quote from: komp on May 18, 2021, 10:09:03 AMhave you had a look through the old mcnninja archive?
Aha, brilliant, ta!! I had just been trying to sift through google results - archives here I come!!
DaveH
Found the discussions about this exact thing, but was either broken links or, maybe, a file that had been uploaded to the site but no longer available.
A bit more refining of the search and found the info on the zx6r forum, which was as follows:
Quote from: zx6r forumThere was a ZX6-R suspenion guide done in the March 2001 Performance Bikes, for a J1 model.
This should be good for all J and A1 models as they all had much the same suspension.
Stock Rear:
Preload - spring length 180mm
Rebound - ten clicks out from full in
Compression - ten clicks out from full in
Ride height - zero
Stock Front:
Preload - 14mm showing
Rebound - 7 clicks out from full in
Compression - 9 clicks out from full in
PB Settings:
Rear:
Preload - one full turn back if weighing less than 14 stone (in full gear)
Compression: 8 clicks out from full in
Ride height - +8mm (+4mm is recommended for road riding and still improves things)
Front:
Preload - 4 lines showing
Rebound - 4 clicks out from full in
Compression - 6 clicks out from full in
Rear ride height made a big difference.
Easy adjustment on the J model but I thing the A model required a spacer.
Apologies for the delay, found them on an old hard drive.
DaveH
coyote
Funny it is still up on my old website.
That is my old service provider from 15 years ago and they have still not taken it down.
There is a wiring diagram there too
www.johnodell.eclipse.co.uk/zx6rg-susp.htm
DaveH
Quote from: coyote on June 22, 2021, 12:53:21 PMFunny it is still up on my old website.
Great, ta  :afro:
