afternoon all - was after some advice....
Right now, I've got a wireless thermostat and corresponding receiver on the boiler and a separate thermostat that controls the return flow from the underfloor heating...
Does any one know if I can control a boiler and the underfloor heating pump with one thermostat - so that they both are turn on at the same time?
Thanks all!
I know you will not see this as the post is so old but yes you can, but the best way to use underfloor heating is to run a stat on each zone of the system.
The above is assuming that both are wet systems
