well the ktm (the second one) is sold
now I need to decide on a new bike problem is we are moving next week so said bike will be left outside the window on the path , chained the hell up of course
got about £2500 to play with just been offered a tlr1000r for £1650 which is a bit tempting ,but on the other hand I'm considering taking the b1h out of retirement and putting it back in road trim only problem is its been sat for the best part of 6 years am I going to be able to do everything that would be needed to it without a work shop?
I'm thinking all new fluids new battery new tyres new filters and checking all the bolts etc?
Don't buy the TLR, stick the B1 back in road trim and sell all the carbon crap. Remember why you kept it for so long in the first place.
Sent from my iPhone using Tapatalk
Failing that, sell the bike and buy a new car like I've just had to do lol
get the b1h out and try and put it back in shape... we need the entertainment on here
Quote from: Andy M on April 18, 2016, 11:11:11 AM
+1
Well the b1h is insured once again......... For the sum of £22, 17 of which was an admin charge
Well Monday is the day I'll be picking the bike up. Just hoping I can strap it down only ever transported in a wheel chock van , so to get the bike back on the road what should my plan of attack be , it has been left with fluids....
Don't look at me and my new bike as I'm shy and boring.....
Quote from: Carbon_ZX6R on July 07, 2016, 07:18:58 AM
Quote from: Carbon_ZX6R on April 17, 2016, 07:16:07 AM
If you ask for advice that you've previously already answered yourself...... and you ignore it...... will it cause a paradox in the space-time continuum and result in the universe imploding within a nanosecond?
Don't take the risk...... just do as you say......
Quote from: Lord Danoir the first on July 07, 2016, 12:01:43 PM
:rofl: :rofl: :rofl: Could it not be that if Carbon doesn't stay true to form the world as we know it will come to an end?
Quote from: Gilby104 on July 07, 2016, 12:25:04 PM
obviously I need to change the fluids but do I drain the fuel and drain oil cold or will that be a pain etc etc?
cant wait to get back on the b1h , I'm thankful carbon doesn't rust :)
Quote from: Carbon_ZX6R on July 07, 2016, 02:12:08 PM
its been sat for the best part of 6 years.
(https://media.giphy.com/media/l3E6MlCQSxa7HZY0E/giphy.gif)
well tomorrow is the day
so its going to be new headrace bearings
fork rebuild
shock service with new spring
steering damper rebuild
new wheel bearings
new tyres
new battery
new filters
new plugs
new oil
pray to god the meta alarm doesn't cause a problem....
think that will be everything...
Fresh fuel and hope the injectors aren't screwed, and new coolant.
Good day's work that
Quote from: Lord Danoir the first on July 10, 2016, 10:17:30 AM
just going to drain the fuel out and the oil cold will take a while but I think its better than starting it with that crap in there
Pay someone to do the above jobs. Going from your past experiences it will save you a fortune. ;)
Quote from: terry950sm on July 10, 2016, 01:28:20 PM
I am fully capable! Of the for mentioned tasks!
The alarm however may defeat me
Quote from: Carbon_ZX6R on July 10, 2016, 03:44:41 PM
Aforementioned.
Quote from: Alzo on July 10, 2016, 03:49:31 PM
Aforementioned.
I don't even know how auto correct fucked that up
Quote from: Carbon_ZX6R on July 10, 2016, 05:07:33 PM
Aforementioned.
:pottytrain2:
well shes out of storage FEELING A BIT SORRY FOR HER SELF NEED TO DE-SPIDER HER
some how her tyres have held the same pressure
getting quite excited about putting her back on the road now , what I am a bit worried about is well I opened the tank and got hit with the smell I can only describe as varnish and there appears to be rust inside the tank , now do I need to do something about the rust? wont it clog the injectors?
obviously I'm going to drain the varnish/petrol
other thing is the chain and sprockets appear to be fine strill going to slap a new set on but might wait till after mot
If there's rust inside the tank I would be very careful, and by careful I mean I'm a proper fanny and a bit of a fuckwit when it comes to mechanics and I wouldn't dream running the bike with even surface rust in the tank.
Don't elevate yourself above my status.... ;)
Quote from: PJ on July 13, 2016, 11:23:35 AM
that was my thinking that bits of rust will end up in the injectors?
well what are my options? id rather not replace the tank as its mint
Quote from: Carbon_ZX6R on July 13, 2016, 11:51:54 AM
I don't know if the tanks are coated inside in some way or have a treatment applied but I'd speak to a local garage and see if theres a way to safely remove the rust
Quote from: Carbon_ZX6R on July 13, 2016, 10:23:17 AM
and edit out all of this 'her' business before Danoir gets here!
OK the old school way to deal with this is to take the tank off, remove pump find a way to seal the hole the pump goes in (was easier in the old days as there was only a filler cap and tap ;) ) put some smallish nuts in the tank and a bit of clean oil, shake it like buggery to dislodge any rust. Then thoroughly wash it out to clear the loose bits. New filters in the fuel lines and pump in this case, fresh fuel and pray.
Now the varnish smell, this is what petrol does nowadays and why bikes with carbs can be a right PITA if they have been left stood. I would suggest flushing the fuel pipes etc through with clean fuel in the hope it clears off and varnish deposits.
There used the be a product called Petseal that was designed the coat and seal the inside of petrol tanks, no idea if it is still availabe.
Good luck.
Anyone who refers to a car or bike as her/she needs a thunder punch up the vagina......
'kin ell is wrong with people?
Quote from: Gilby104 on July 13, 2016, 12:42:21 PM
I love that you take notice of the shit I say....... we should be bezzies
Quote from: Lord Danoir the first on July 14, 2016, 07:31:27 AM
Is it acceptable to refer to your mighty stead as "The Beast" or is this also frowned upon?
Family history, came from an old motor launch of my Dad's that was notoriously a bitch to start then transferred to my first bike.
Quote from: Lord Danoir the first on July 14, 2016, 07:32:46 AM
Are we not........
Sh1t
Quote from: Green_Ninja on July 13, 2016, 10:10:21 PM
Good luck.
so your saying I will need a new fuel pump also?
just checked and there cheap thank fuck....
this is a stupid one is the tank steel or aluminium? I cant remember which if its steel I'm golden....
there seem to be actual liquids that are designed for this (acid based) but all the ones I have seen are not suitable for ally tanks
then I found this
I thought it was a joke
http://www.therevcounter.co.uk/threads/35994-Rust-Inside-Petrol-Tank-II-The-Test
It's a Kawasaki...cheap steel.
well that's one yuasa battery ordered......
I refuse to scrimp on quality so this is going to hurt the old wallet
right the spark plugs had about 300 miles on them before it went into storage will they need replacing or just a clean?
Clean
Quote from: Alzo on July 15, 2016, 11:41:54 AM
Clean
well that saves a few bob I think ill order my oil and filter online after my local dealer insisting the kwak has 2 oil filters................
any places people order there filters and oil from?
can get 4ltr motorax and a k&n filter for £30 delivered
Quote from: Carbon_ZX6R on July 15, 2016, 12:13:24 PM
Any places people order there filters and oil from?
Wemoto
well that's oil and filter ordered now , air filter should be ok after a wash now need some coolant , got to de rust the tank going to try the vinegar trick if it works it works if not there are other Homemade ways , don't fancy pouring acid in it if I'm honest but hey ho , once that's done ill fit a inline fuel filter just incase , and well I cant see exactly how rusted it is until the tanks drained
[/quote]
[/quote]
No where did I say you would need a new pump, I mentioned the fuel filter in the pump :shocked:
Ooooo is that cleanable? I thought it was a sealed unit
Quote from: Carbon_ZX6R on July 15, 2016, 07:00:57 PM
The ZX10r ones certainly are so can't see the ZX6R ones being any different
Cheers well it's worth a go I'll find out when I take it off , I'm really hoping it's only rusty where there was no fuel
had to de-rust the inside of the tank on my trackbike last year
vinegar/coke didn't work, electrolysis did :)
1. remove the pump
2. mix soda crystals with water (to create an electrolyte) - got the soda crystals from local morrisions
3. fill tank with electrolyte
4. place iron rod into the solution via the fuel pump hole
The iron rod can't touch the tank. So a bit of electrical tape to insulate it round the pump hole.
5. Connect a 12v battery (or even a battery charger)
Positive to the iron rod
Negative to the tank
Every few hours take the iron rod out and clean it up. I changed the electrolyte a couple times so it was easier to see how things were progressing.
Once the bubbles stop, there is no longer a chemical reaction.
Do this in a well ventilated area. I did mine over a weekend.
(http://i57.tinypic.com/qntv68.jpg)
(http://i58.tinypic.com/dvgcxt.jpg)
(http://i60.tinypic.com/insk02.jpg)
(http://i59.tinypic.com/mkayh5.jpg)
plenty of youtube videos of the process
the rust in my tank was caused by fuel foam baffles.. at the top of the tank by the filler
take the pump apart and clean the tea bag filter and all will be good
Witchcraft I tell thee.
Can't see Carbon managing that with burning his house down.
Quote from: Dom1 on July 19, 2016, 02:52:49 PM
well that should even be even cheaper , and id imagine do a better job than the vinegar I may just give that a go
I'm a bit worried about the old it's been in there 6 years , I can't imagine it's rusted in there but do i warm the engine to drain it , should I drain it then flush it through with cheap oil or well any ideas?
Drain it...put flushing oil through.
Quote from: Alzo on July 19, 2016, 10:21:38 PM
Drain cold? Fill with cheap car oil just to flush it through then change filter and out correct oil in?
Warm it up...drain...buy Flushing oil...fill...run...drain...fill with proper specified oil.
Quote from: Alzo on July 20, 2016, 06:38:26 AM
Cheers for clearing that up I was a bit worried about even starting it with that oil due to the fact it's 7 years old...
Warm it...no need to allow engine to reach operating temperature...enough to think the oil...then out it comes. Flush oil will come with instructions.
Quote from: Alzo on July 20, 2016, 08:02:14 AM
your saying there oil actually meant for flushing? this I did not know was just going to flush with car Castrol gtx
Yip...Flushing Oils available
Quote from: Alzo on July 20, 2016, 11:00:19 AM
Just found one on eurocarparts for a tenner 4.5l so I'll get that
I'd avoid flushing oils on an older engine.
Oil tends to collect around the wear areas around shaft seals etc inside the engine, and while it's old oil, it does a job of plugging the wear. Flushes can remove these deposits and cause leaks.
I've had a few issues with this, so now I do what you originally suggested.
Quote from: Lord Danoir the first on July 20, 2016, 12:21:37 PM
Car oil flush it is then
Quote from: Carbon_ZX6R on July 20, 2016, 12:54:00 PM
but flushing oil will guarantee a nice clean engine.........
https://vimeo.com/129205411
Quote from: Lord Danoir the first on July 20, 2016, 01:08:00 PM
Danior being given the willies by unexpected turn of events and Carbon following his advice!
Agreed but I'd prefer a slightly dirty fully functional engine.....
Quote from: Gilby104 on July 20, 2016, 01:09:43 PM
in this litigious society we live in..... one simply cannot be too careful.
Well that's 4l of Castrol gtx £13 if I'm going to flush it with car oil half decent can't hurt well hurt it less possibly , going to take the tank off tomorrow and try and do the electrolyte , if I have time
If your engine cannot take a Flushing oil without issue then it's not worth shit.
I disagree with Dan in the strongest terms possible (I don't really...but aint them lovely words when all put together)
At times you really make it hard to follow advice.....
Drain it cold. The oil will have settled in the sump by now. Leave it to drain for as long as you can.The longer the better. Overnight at least. If you have paddock stands, front and rear, put the bike up on the stands. Take oil filter off and let it drain from there too. After filling up with fresh oil, stab the starter button a couple of times to just get the new oil round the engine. You don't want the engine to start until the oil has reached all round the engine. Oil pressure light should go off. Once you have the oil circulated, start the engine. Let it tick over until the temperature is up before you start revving it.
so much advise to choose from....
What I said. And I don't believe in using a flushing oil, as I believe you don't drain all that completely, this leaving some in your engine to dilute the fresh oil you have just put in. If you want to flush it just use normal oil.
Quote from: Carbon_ZX6R on July 20, 2016, 05:13:39 PM
Got to give you that one Carbon..... your MO is a lot simpler on the whole.
Read this:
http://www.carbibles.com/engineoil_bible.html
It hurts to say this...a lot...but Grumpy and Dan may be right...God that hurt.
Took the rear end off to put the battery in and the fucking alarm still works and so do the clocks etc I am quite shocked but over the moon was worried it would be immobilised , although I have noticed something my battery seems to be just plonked in a think something may be missing would someone with a b1h be able to share a photo of under the seat?
Battery sits in it's own slot behind the fuel tank and under the riders seat. There is no straps needed to hold it in place. Once the seat is on it is not going anywhere.
Quote from: GRUMPY on July 21, 2016, 05:31:30 PM
I was starting to think that thought I remembered that being the case , cheers grumpy
If your engine can't take an oil flush, save your money on the oil and put it towards a bike that isn't a pile of shit.
Quote from: Tiiimmmaaayyyy on July 21, 2016, 09:04:22 PM
Oh!!!!
But how will he know, unless he uses the oil........
You have been given conflicting opinions....it's your bike...go with your gut...if it were my bike I would use Flushing Oil...I would want all the Gunk out...the end.
or as an alternative buy some cheap bike specific smei synth engine oil, Halfords for example. Drain the current oil cold as per Davy's advice i.e on paddock stands overnight.
fit new oil filter, fill with the cheap semi synth, pull the plug leads off or take plugs out and spin the engine on the starter until the oil light goes out. Reconnect/refit plugs, start bike allow to idle untill the temp gets to about half way before revving, allow to run until fan kicks in, switch off and leave for 30 mins or more, Drain oil thoroughly, if you want to be really really sure fit another new oil filter, refill engine with quality bike specific semi synth oil of your choice (yes there's the age old argument about semi verus full synth but Kawasaki recommends Semi so go with that) as ong as all other checks have proved successful ride and enjoy.
Can't belive I've just typed all this becaus eas usual you will go your own way anyway ;) ;) ;)
Quote from: Green_Ninja on July 21, 2016, 10:28:17 PM
Can't belive I've just typed all this becaus as usual you will go your own way anyway ;) ;) ;)
I'm not even sure he's a real person.
I think what I'm going to do is drain it cold as it will be all in the sump so there may not be that munch gunk , it was fresh oil when it was last round the engine and it's just sat, I'm then going to put the Castrol gtx (car) and use that to flush out the rest
I'm only staying away from flushing solutions as I've read alot of bad things about them and when I enquired about flushing oil, on the back "not recommended for use with motorcycles" if there is alot of gunk I'll have no real choice but I can always flush it later if its needed
I seem to remember Kawasaki recommending fully synth oil for the B1?
+1
Got some spare olive oil in the kitchen?
carbon you don't half provide the entertainment value on here
I'm not ignoring anyone's advice its all very much appreciated and has all been taken on-board , there is risks to every option so I have to work out which one I think is the least
You could not make this up. Suppose it keeps the forum going. ;)
Nice to see a Kawasaki issue for once...
Quote from: Carbon_ZX6R on July 22, 2016, 02:48:46 PM
it was never a Kawasaki issue...... it's always been a 'you' issue.
never change.......
Tanks off , house stinks of petrol varnish now it's horrible , it is rusty but not as bad as I expected got a shit load out shaking it but what I've noticed is it's clumped and loose , the pump is caked in it as well going to scour that , not sure how to get to the filter on the pump though , so tomorrow I'll do the electrolysis just not sure how much soda crystals to use , i.e per litre
Currently doing the electrolysis started 5 mins ago so far no bubbles as best I can see? Using a jump starter and a tent peg so not sure if it takes a while to get bubbles
mot entirely how but somehow the outside of the tank does not conduct I placed the negative on the tank and nothing ive now put it on the bolt of the mount at the top of the tank(bit that bolts it to frame) put the positive electrode (multi metre) in the water and the other on the tank and there seems to be a tiny current ( and a couple of very small bubbles have appeared
Any pictures of the re-build/ re-fresh
Quote from: terry950sm on July 25, 2016, 12:46:37 PM
A few I'll put up later , the fucking sump bolt just sheered off..... Managed to get it out luckily cheap magnetic one by the looks
here are some pictures of the bike during the rebuild , didn't take many as ive been to busy doing!
this is how she was when I took the bike out of storage
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160711_151729_zpsyp9grzex.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/Mobile%20Uploads/IMG_20160711_151729_zpsyp9grzex.jpg.html)
here is the bike after I decided to get off my arse
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160723_154943_zpsbluvvhxf.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/Mobile%20Uploads/IMG_20160723_154943_zpsbluvvhxf.jpg.html)
this is how it stands at the moment
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160725_122455_zpsdjk8dzl9.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/Mobile%20Uploads/IMG_20160725_122455_zpsdjk8dzl9.jpg.html)
and this is the inside of the tank after the electrolysis , its not perfect but its a lot better, the photo is showing the bad bit
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160725_154816_zps9buje5tk.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/Mobile%20Uploads/IMG_20160725_154816_zps9buje5tk.jpg.html)
The oils been draining for 48 hours I'm debating if I should even flush it with car oil , there was no clumps what so ever and the oil was still brown .... And I'm not sure if the car oil would cause the clutch to slip or not...
I'm not happy with the tank I've taken the pump apart and rinsed the filter which is tea bag coloured now was quite a bit of rust in the sump attacked that with a wire brush , the tank rinses through clear now and alot of what looks like rust is crystallized petrol ,am I right in thinking as it's fuel injected I cant splice in an extra filter due to the pressure reduction caused by the filter, also am I correct in assuming that if some rust did make it past the pump filter it would potentially just clog the injectors as apposed to making it into the combustion chamber?
New tank time love....... you're right in that the larger particles will get held back by both the filter and then the injectors, but before you know it, it'll be running like a bag of shite and you'll have killed your injectors...... and you'll end up doing it again.
What's more of an issue is the microscopic debris that WILL make it through to the combustion chamber. High revving engines don't cope well at all and the valves and seats tend to be quite soft when bombarded with small particles at high frequency....... and let's not forget the nature of the debris..... it's metal.
Do yourself a favour..... you dug deep for that, frankly, pointless carbon bling..... you owe it to the bike to sort this before you kill it and it ends up back in your shed or on ebay.
Well this presents a problem I looked for a new tank and can't source even a reasonable condition one , I know there are other ways of deducting the tank I.e acid based chemicals and I have seen some guides online that have seen the most rusted tanks your likely to see come up spotless inside but then I have the trouble of recoating the tank inside ,desposing of the acid without spilling it or getting it on the perfect paint , I'd probably chance it if I wasn't planning on keeping the bike but I don't want to sell it , the fuel pump will need some work and possibly replacing unless I can remove all the rusted parts and deep clean them , which I might be able too ,I might have to get a quote from a specialist to do the tank as your quite right Dan and it was my thinking as well that it could be fine tomorrow , next week or even for a year but eventually it's going to fuck it up , I'm going to have to put the new oil in and just leave it for a bit as I don't like the idea of leaving the engine dry
Think I need to give the electrolysis another go as the reaction was very weak and only lasted couple hours I was told a cap of soda crystals per litre I'm thinking that may have been wrong
Quote from: Carbon_ZX6R on July 27, 2016, 02:09:11 PM
Is the hair growing back already?
Not quite sure what you mean. I haven't quite pulled it out from frustration yet
Electrolysis for Hair Removal :shocked:
Quote from: Jonesy on July 27, 2016, 05:50:27 PM
Urrrgh walked into that one!
With regards to the oil should I leave it dry or should I just put the oil and new filter in? But be unable to start it at the moment?
May as well put the oil and filter in to be honest one less thing to forget to do later ;)
Quote from: Green_Ninja on July 27, 2016, 09:40:10 PM
Was just making sure it wouldn't cause problems by me not warming it up etc and properly doing it etc
Don't like the idea of it being dry , the tanks a big enough problem , I don't fancy stripping the engine
Put the oil in...pull the spark plugs out...put the bike in fourth gear....push it for 1000 yards with the clutch out...then push it 1000 yards back...that will have built up the oil pressure and circulated it nicely.
Quote from: Alzo on July 27, 2016, 09:50:31 PM
Good idea that Alzo :azn:
Quote from: Green_Ninja on July 27, 2016, 10:18:12 PM
I thought so. :azn:
I almost took that seriously
Quote from: Carbon_ZX6R on July 28, 2016, 06:34:44 AM
I almost took that seriouslu
And so you should.
Question is do I just put the new new filter on and dump the full 3.6l in or what as I can't start it so getting it to the correct level is easier said than done
Quote from: Carbon_ZX6R on July 28, 2016, 07:52:44 AM
Pop the filter on, fill the oil to the upper mark, run the engine and then re-check the level. Some people put some oil in the filter before installing it but I've never bothered. Nothing has blown up yet.
My problem was I can't start the engine....
Stick 3 litres in...turn the engine with plugs pulled to circulate...and when you are ready to fire up for real run until warm...cool it...top up as necessary.
Quote from: Alzo on July 28, 2016, 08:22:58 AM
so pull the spark plugs stick it in gear and push it?
I meant hook up a battery and turn it over using the Starter motor. All depends on how long you intend to let the bike sit before you're ready to run it again.
Quote from: Alzo on July 28, 2016, 09:18:36 AM
ahh I intend on it sitting there the least amount of time possible just need to tackle tank and pump as I cant put them on with rust , battery is connected, is the removal of the spark plugs essential?
Fill it with oil and then rock it from side to side for an hour to get it around the engine
Quote from: Tiiimmmaaayyyy on July 28, 2016, 09:46:26 AM
Dont forget to shake it all about :cool:
here we go again
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160729_132944_zpstlibxji1.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/Mobile%20Uploads/IMG_20160729_132944_zpstlibxji1.jpg.html)
there are bubbles but the waters not the colour it was last time , but saying that I have put 2kg of soda crystals in it this time.........
well the bikes all but back together
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160729_155432_zpsxazltobu.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/Mobile%20Uploads/IMG_20160729_155432_zpsxazltobu.jpg.html)
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160729_155438_zpsstld6hut.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/Mobile%20Uploads/IMG_20160729_155438_zpsstld6hut.jpg.html)
still a fair bit of carbon...
Looks good......................................for a Kawasaki ;)
Quote from: terry950sm on July 29, 2016, 04:46:26 PM
Almost a compliment there Terry :tongue:
Finished the electrolysis again and there is no noticeable difference the water ran clear no flakes that I even noticed ,is it possible that it's no longer rust but crystallized petrol as my understanding is electrolysis won't do anything to that?
How do I get rid of the crystallized petrol? Is it harmful if left?
Just buy a new tank......
£941........ Otherwise I would other than the inside the tank is perfect as is the bike I can't even find a used green tank let alone a good condition one. Here is it after the 2nd electrolysis I'd say it looks worse , but it didn't budge anything this time and I did it for 5 times the length of time , I can only imagine that it's not rust in there now but varnished petrol
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160731_085634_zpsyhtkqnas.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/Mobile%20Uploads/IMG_20160731_085634_zpsyhtkqnas.jpg.html)
It definitely looks worse..... Not sure how that's possible.....
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160731_091656_zpszht35inp.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/Mobile%20Uploads/IMG_20160731_091656_zpszht35inp.jpg.html)
Top one is after first electrolysis bottom is after second attempt wtf it's got worse!
Pay someone to refurbish your one.
Quote from: The Wizard of MOz on July 31, 2016, 11:36:17 AM
I'd quite happily do that as I imagine there is a professional method , I have popped into and rang round countless places and nobody seems to know how to do it , I'm tempted to cut the tank sand the shit out of it remote the inside and weld it up but I'd rather not I'm currently exploring the donor bike route....... If that don't work I'll try one of the more aggressive home solutions "concentrated acid" coz at the end of the day a fucked tank is a fucked tank I suppose....
Is it worth trying it again? Like you said, a fooked tank is a fooked tank. Is the stuff inside solid? Could you fill it up with water and stick a jet was in to aggitate the stuff off?
I'm going to try the electrolysis one more time , at the original mixture and I won't leave it over night , going to attack it with a steel paint stirrer and see if it comes off easy , I'll try the acid next if electrolysis doesn't help it sure can't make it worse
Bin it and buy a good secondhand one...or new.
And don't argue.
Quote from: Alzo on July 31, 2016, 07:56:53 PM
And don't argue.
ive gone one better ive just bought another b1h........ (well won it) not paid for it yet
tatty fairings but good tank and lots of expensive parts including
Nitron Race Rear Shock
•Forks have K-Tech 20SSK Piston kit and Flow Control Valves.
•Ohlins Steering Damper
•HM Quickshifter
•Power Commander 3 USB
•Akrapovic Full Titanium Race System
•BMC Race Air Filter
•Accossato Front Master Cylinder
•Clutch has been replaced with a slipper clutch from the 05/06 ZX6R
•Meta Alarm + Immobiliser
•Gilles Rearsets
got it for a steal!
bloke should have spent sometime just tidying it up cosmeticly would have got a lot more from it , ill make a profit if I sell it on , or if I break it I should make alot
and it only cost me the price of 2 new tanks!
Quote from: Carbon_ZX6R on July 31, 2016, 08:08:53 PM
And don't argue.
•HM Quickshifter
•Gilles Rearsets
got it for a steal!
seems to be a bit of an extreme way the sort your tank out, but hey whatever works ;)
Well it gets me a new tank plus a shed load of party bits for penny's , I looked high and low for a good condition used tank but lets be realistic most tanks for sale are off crashed bikes so the chances of finding a mint one wore slim so if all goes well I'll have a serviceable tank that may need a respray to get it perfect , and alot of performance parts and I'll still probably have a bit of cash in my pocket after its all done
Just found out I need to go onto an RAF base to collect it .... :cool:
Quote from: Carbon_ZX6R on July 31, 2016, 08:54:43 PM
which one?
RAF benson
I am now wondering how I can remove a shock without an Abba stand.....
Quote from: Carbon_ZX6R on August 01, 2016, 07:05:20 AM
2 axle stands, or tie down straps if you have roof beams to support the bike.
Quote from: GRUMPY on August 01, 2016, 07:22:26 AM
Axel stands are a brilliant idea didn't even think of that , I'll need 4 unfortunately as I'll be switching them
picking the donor bike up tomorrow
so I will be removing and fitting
nitron race shock
power commander
hm quickshifter
k tech fork piston kit (if I can work out how)
Accossato Front Master Cylinder (if its worth it? as ive never heard of them
so hopefully ill put my bike through mot end of the week
not sure if I should fit the ohlins steering damper as I have a hyperpro rsc damper fitted?
(http://i12.photobucket.com/albums/a230/icescape/terrys/garagektm162.jpg)[/URL]
(http://i12.photobucket.com/albums/a230/icescape/terrys/garagektm157.jpg)[/URL]
How long until the "I dented my new tank when the bike fell off the stands fitting the new shock" post?
How do you know this tank is OK? Did he send you photos of its interior?
He's a pilot is his word not good enough? First thing I asked about the tank and he was honest about a couple of marks told me there's no rust and I'll be able to see that as it's on reserve , went into alot of detail about things I wouldn't have noticed which is always reassuring
Quote from: terry950sm on August 01, 2016, 01:43:07 PM
right you have the shock off and I see the padock stand on the rear have you put the pipe through the swing arm to keep it steady? not 100% about how you have pulled the shock?
Quote from: Carbon_ZX6R on August 02, 2016, 07:12:41 AM
:rofl: :rofl:
Aahhhhhhhhahahahahahahahahahha - nice one.......
That was a joke. But it's what it looks like to me
with the swing arm extended and the shock unloaded...... it simply unbolts love.
Get someone to do it for you. ;)
well the bike and me survived the 100mile trip from raf benson (my phone however didn't)
the bikes in better condition than I thought and there are more bits on it to remove , the tank is in quite good condition if I'm honest which is good the rear shock can only be described as beautiful!
photos will be uploaded shortly
what are you going to do with all the left over bits?
Quote from: Andy M on August 03, 2016, 10:38:30 AM
asking us where they go....... probably
The donor bike will be sold as a complete mostly bike a few bits will be sold , there will be a steering damper for sale , master cylinder possibly an akra
here is the donor b1h
(http://i1314.photobucket.com/albums/t574/blackstarracing8/IMG_20160803_170132_zpshel5aayo.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/IMG_20160803_170132_zpshel5aayo.jpg.html)
(http://i1314.photobucket.com/albums/t574/blackstarracing8/IMG_20160803_170139_zpszfdp1fbu.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/IMG_20160803_170139_zpszfdp1fbu.jpg.html)
(http://i1314.photobucket.com/albums/t574/blackstarracing8/IMG_20160803_170158_zps36kpvcy3.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/IMG_20160803_170158_zps36kpvcy3.jpg.html)
(http://i1314.photobucket.com/albums/t574/blackstarracing8/IMG_20160803_170202_zpsdipvizxp.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/IMG_20160803_170202_zpsdipvizxp.jpg.html)
(http://i1314.photobucket.com/albums/t574/blackstarracing8/IMG_20160803_170152_zpsh16gnwec.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/IMG_20160803_170152_zpsh16gnwec.jpg.html)
(http://i1314.photobucket.com/albums/t574/blackstarracing8/IMG_20160803_170218_zpsp1ilbsnx.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/IMG_20160803_170218_zpsp1ilbsnx.jpg.html)
(http://i1314.photobucket.com/albums/t574/blackstarracing8/IMG_20160803_170146_zpseadiwbrr.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/IMG_20160803_170146_zpseadiwbrr.jpg.html)
(http://i1314.photobucket.com/albums/t574/blackstarracing8/IMG_20160803_170212_zps24byks35.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/IMG_20160803_170212_zps24byks35.jpg.html)
(http://i1314.photobucket.com/albums/t574/blackstarracing8/IMG_20160803_170225_zpsxdjjxrm6.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/IMG_20160803_170225_zpsxdjjxrm6.jpg.html)
(http://i1314.photobucket.com/albums/t574/blackstarracing8/IMG_20160803_170252_zpsylof4ud8.jpg) (http://s1314.photobucket.com/user/blackstarracing8/media/IMG_20160803_170252_zpsylof4ud8.jpg.html)
I do have some questions ,
what exactly do I have to do to remove the and then fit the quick shifter , and power commander , never put either in so not sure , shock I can work out and master cylinder I imagine its just swop then bleed brakes?
also I have a feeling the pistons in the forks might be hard to switch over?
also it has a full race akra as I thought mine did (it does not)
the link pipe is damaged as you can see in the photo how hard is it to get a replacement link pipe or have the dent removed? also would my end can and the race end can be the same or different?
Why not keep that, then sell your other bike?
Swap the forks over.
Also, how did you think you had a full system on yours ?
Power commander is just plug and play. Follow the wiring till you find the multi plugs.
Quote from: Phil_8 on August 03, 2016, 06:31:00 PM
Mine has 12k miles this has nearly 30k
Quote from: GRUMPY on August 03, 2016, 07:14:47 PM
Never really looked at mine close up but it does have titanium headers maybe it is a full system but it's different
Quote from: Carbon_ZX6R on August 03, 2016, 07:22:08 PM
But is in one piece and apparently working.
Quote from: Dom1 on August 04, 2016, 08:53:06 AM
True but all mine is missing is a tank at the moment
That is an important part and will improve your bike's performance.
Quote from: Dom1 on August 04, 2016, 09:40:49 AM
I know and if I add fuel to it also.... Coooor
I reckon you are a really nice person, to meet in the fiesh. :azn:
Take the notice of the negativity and keep doing what you are doing. Bringing a smile to my face everytime I visit this Forum. :azn:
Quote from: terry950sm on August 04, 2016, 11:23:06 AM
As I've said before someone has to keep this place going
My bike has now got its new tank on and amazingly started instantly , topped the oil up , now I just need to drain the coolant and replace, change fluid in brakes and strip the callipers , I may switch the wheels over as the donor bike has newish supercorsas on it , I've removed the ohlins damper I think I'll sell that and keep my hyperpro as in my opinion it's better
Is he a real person though...I keep asking myself.
Other than the nuts and bolts holding me together ;)
you will end up with a load of nuts and bolts left over after you have done all this
Quote from: Andy M on August 05, 2016, 09:45:34 AM
So far I don't have a single but or bolt that I don't know what it's for , probably first time that's ever happend
Carbon is the Donald Trump of this forum. Crazy but makes perfect sense. :evil:
Quote from: Maddog on August 05, 2016, 05:58:46 PM
Don't forget highly controversial!
Quote from: Carbon_ZX6R on August 05, 2016, 06:47:39 PM
Not real?
It's toypop
tried to attempt the shock swop yesterday but realised I cant use my mx stand so I will have to get another pair of axle stands..... :(
Going to book it in for not today (it's up the road) is it safe from a damage to bike point of view to ride it with the old coolant and old brake fluid in? Will it cause any damage etc? Other than say overheating
I'm impressed that your post this morning was not along the lines of - trapped under bike for 2 hours, spent sunday in hospital, no progress with bike ;)
we need more pictures man
Quote from: Andy M on August 08, 2016, 09:49:57 AM
well its booked in for 10am tomorrow for mot
there will be more photos not much to take photos of right this second as both bikes are fully assembled (mine is fully back in road trim)
I cant see any negatives of riding (4 mile round trip) with old coolant other than it might not cool as effective , I may be wrong?
and if the fluids gone funny in the brakes , I only suggest this as I want to do everything in one go as I'm fed up with tank on tank off , fairing on fairing off already
the beauty of working nights I can get stuff done in the day if not somewhat tired , so I'm off now to get another set of axle stands
Quote from: Carbon_ZX6R on August 08, 2016, 07:51:47 AM
as is always said if you are going to do a job do it properly. Why rush the MOT wait until you have done all the work or you'll never finish it.
It will get done don't worry about that just want it all taxed and everything ready to go etc , the new indicators are on , look really good and was only 6 of quid for them I'm a bit surprised though there led but there flashing normally , yet I have a stock relay
bike passed , shouldn't have though as a bolt in the clutch perch was missing , my mot bloke said it sheered but on closer inspection by my self it wasn't there so that's been replaced and tightened , only advisory's wore near legal tred and near legal limit on brake pads , now fuck me I didn't expect it but it road like an absolute dream , and I'm not sure how but the brakes are a lot sharper than the doner bike with its acossato m/c , still feels like a new bike to ride, off to tax it now , then it will be coolant then going to sdo brakes when I order new pads
on that note I'm thinking of swoping the callipers it did have brembos on before I started selling bits , what newer brakes have people put on there bikes?
also with regards to the coolant , what exactly should I be putting in the bike as there seems to me a million different types?
coolants changed , might have made a booboo by not changing the fucking drain washers , but its done now and doesn't seem to leak when running so I may be lucky , didn't put as much coolant in as I expected exactly 2 litres....
Well that's the rear end done with the exception of the new shock , think it looks rather snazzy
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160826_070017_zpstmg8cvic.jpg)
It passed with that tail light, and no rear reflector?
Quote from: Jonesy on August 26, 2016, 09:12:04 AM
Didn't pass with that tail light as not fitted at time why shouldn't it have passed? But it did pass with small plate and no reflector
Quote from: Carbon_ZX6R on August 26, 2016, 09:22:21 AM
I'm fairly sure any tinting of light units is a big no no, not down to discretion, but a complete no no. I could be wrong however.
I've never understood why people would wanna put tiny indicators and reduce the amount of light given off by their lights on a bike. Car drivers seem to have a hard enough time spotting us as it is.... :rolleyes:
My understanding was not to tint headlight but tail lights are acceptable as long as they still emit sufficient light , some Harley's come with tinted rear lights as standard mine did and it was a factory part , them indicators are quite good if I'm honest nice and bright and there not as small as they look , magically I didn't need any resisters for them or a relay not bad for sub tenner indicators , only did the rear light to go with the indis only £15 delivered and OEM plug , not sure how to wire the inbuilt indicators in but that wasn't why I bought it
Quote from: Carbon_ZX6R on August 26, 2016, 09:46:10 AM
I always thought tinted lights were a no no regardless, but I'm probably wrong. Personally I still wouldn't do it, theres enough idiots on the roads without making myself less visible lol
Did the MOT tester not slap you in the face for the number plate slogan?
I think they're supposed to do that.
I believe the requirement is that you prove it or get slapped.
Quote from: PJ on August 26, 2016, 10:19:42 AM
I agree with you ,noon as I got it I compared to see if it was noticeavly dimmer and it's not really if I'm honest still brighter than most
Quote from: Lord Danoir the first on August 26, 2016, 10:28:58 AM
NA he never pays attention to my number plates just makes me get them out the shop quick
Quote from: Carbon_ZX6R on August 26, 2016, 10:54:04 AM
He knows you well then....
Quote from: PJ on August 26, 2016, 11:03:22 AM
I also bet it's nothing to do with the numberplate why he's trying to get rid of you :shocked:
Quote from: Jonesy on August 26, 2016, 12:16:57 PM
I just imagine him following the poor bloke around his workshop like a child......
"what's that?...... why?...... why?...... why?"
"where does the oil go?"
"why does my bike have 2 wheels and not 9?"
"who would win in a fight, superman, or a kawasaki?"
Then walking out with a plaster on his arm and a lolly..........
Dan's post just made me think of this for some reason....
https://www.youtube.com/v/6XVo09I2hSs
Quote from: PJ on August 26, 2016, 02:11:36 PM
oh god...... cue various technical questions relating to butt plugs and the positioning, lubricating and cooling thereof.
Doubtless someone will make them in carbon fibre
Quote from: Lord Danoir the first on August 26, 2016, 02:18:13 PM
Will a carbon butt plug pass an MOT? Is there a minimum depth requirement?
And I thought this was a safe place!!!!!!
Quote from: Carbon_ZX6R on August 26, 2016, 06:57:28 PM
in as much as a padded cell is for a complete mentalist....... but you keep running head first in to the walls
Quote from: Carbon_ZX6R on August 11, 2016, 01:46:01 PM
Never drain coolant via a drain washer - always the lowest hose / jubilee. It'll always weep from there now :-)
well they arrived only ordered yesterday
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160906_144634_zpsmhftb3ln.jpg)
should now have everything to do the zx6rs all at once instead of doing bits left right and centre
right am I being stupid rear wheel removal , remove split pin from nut and brute force? ive put so much force into it ive lifted it off the stand it wont budge , tell me I'm missing something
Muscle, that's what you're missing.
lefty loosey, righty tighty
Quote from: Wallace12R on September 13, 2016, 01:08:31 PM
I assure you I'm not , got the misses to lean on the seat and I still lifted it off the paddock stand , so I don't need to loosen the adjuster bolts? just split pin out and brute force? going to break my ratchet if I use much more
Stop being a pussy and stamp on the thing! You may need a breaker bar opposed to a ratchet!
Quote from: Jonesy on September 13, 2016, 01:47:15 PM
I thought someone may say that....
Quote from: Carbon_ZX6R on September 13, 2016, 01:28:20 PM
Alright! Charlie Big Potatoes
Length is what you need. Plenty of leverage. Especially if it was put on with a gun without much care for proper torque settings
Quote from: Phil_8 on September 13, 2016, 04:00:07 PM
Sounds like he's more Charlie New Potatoes
What we do know is he's lacking length!
My breaker bar is 30 inch I'll have you know!
Quote from: Carbon_ZX6R on September 13, 2016, 05:07:01 PM
All torque and no trousers ;)
Push down on the bar rather than pulling it up.
Quote from: GRUMPY on September 13, 2016, 05:31:21 PM
Ya know after coming back inside having been defeated I thought why the fuck didn't I do it the other way
Now I say that I did try it pushing down and still didn't budge
right taken the acossato m/c off the bike to put on mine removed the brake switch hoping to use it but noticed it was the over the mudguard brake line set up so need a different banjo switch
I need the double banjo am I correct that the the one in link is the same connection if I just pull the white plug off?
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160913_190706_zpsjhjsobfv.jpg)
http://www.ebay.co.uk/itm/Motorcycle-Hydraulic-Double-Banjo-Bolt-Brake-Pressure-Light-Switch-M10-x-1-00mm-/152238957622?hash=item2372262436:g:0iQAAOSwi0RX1pnW
another problem is do I need the m10 x m1 or the m10 x m1.25
well this should budge that dam nut if not I have a problem
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160918_095515_zpserucixqx.jpg)
then all I need to do is work out how on earth to use my new torque wrench (only ever had digital ones)
well this is what I did today.........
got the breaker bar on it and it undid very easily and then I powered on
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160918_145639_zps6nwya3ye.jpg)
them centre work stands are bloody brilliant
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160918_145752_zpsyiygxssv.jpg)
switched the rear wheel over and the shock now running a 180 60 17 on the rear over the 55 looks a lot bigger
then as if like magic both bikes put back together ,
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20160918_145821_zpsjyiyk0jl.jpg)
right the forks have been switched over , ran into a problem with one calliper being seized to the mount so had to switch them also fitted the ones from the donor bike to mine and they appear to be rubbing(no lines connected or fluid) although all the fluid wouldn't drain from the nipple for some reason) and when I turn the wheel at a certain point there is a clink , ive checked my disks and cant see or feel anything , any idea what's causing this I'm not to good with brakes
can you fit the other wheel with discs into your and see if the problem is eliminated? If so you might have warped disc on yours which wasn't showing up with brake pads that were less worn and sat further apart from the disc in the calipers.
Or possibly the wheel and disc in the donor is not from that bike but something else that fits that year and the gap to discs is slightly different?
Quote from: Andy M on October 10, 2016, 08:44:49 AM
I suppose it could be warped disks mine had no meat left on the pads and these have loads and it only seems to be the right disk . although the disks on my bike have only done 13k , ( the wheels are identical as are the disks the all oem)
ill check the disks hopefully tomorrow if I have time , if its not the disks what are the other possibility's? if I'm having to replace the disks for the price of them I might as well get a 320mm conversion kit ,with brembo m4 callipers , but I'm not sure how the m4 is as a calliper but if they do need replacing it has to be an upgrade or I begrudge the bike the money
not had time to check the disks properly but did have a look and the offending calliper just doesn't look right the pads don't seem to sit how they should
very hard to see in the photo
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20161018_125036_zpsptm9cjde.jpg)
you could at least have given them a clean
right I switched the wheels over it is still doing the sound I recorded it best turn volume up
http://vid1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/VID_20161028_092731_zpsr8iemtsd.mp4
in my opinion its not the disks both wore fine before they wore switched over but the callipers off the diner bike looked fucked , could it have anything to do with the pads just not sitting right?
also tried to drain the rear mc and res via the bleed nipple and nothing? had old fluid in it , is it just gunked up or am I doing it wrong?
If youre happy with the wheels and discs being true, then change the pads and see if that helps. Personally, unless its effecting the bikes braking id not be too worried
Re the rear caliper, id use an eeziebleed type device which pushes fluid through under pressure from the M/C. Ive got one you can borrow if you dont want to buy one. Id need it back asap though as i need to do my car at some point
I've got a mity vac like thing(is that similar?) that sucks it out and it didn't budge the fluid out the res , ordered a new hrc res and it's gunked to hell , I do need to sort the front brakes and see if they are biting, I want to change the calipers just not sure what ones to use , I'd like a direct bolt on if possible
Well the calipers on the B1/K1 are the same as the 04/05 ZX10 and i know a direct replcement is the ZX6r/ZZR Nissin Calipers as i have them on my 04 ZX10. I picked mine up for about 80 quid so may be worth a punt. The Nissin calipers are much better than the standard Tokico calipers
Mittyvac i presume sucks? The eeziebleed pushes and is used at about 20 psi. Id give the eezie bleed a go as ive never had an issue with it
https://www.youtube.com/watch?v=UoCV6JSxzH0
I may try something like that when I've got time , with me starting new job Monday my times going to be less free , I've searched high and low for the missing zx6r calipers there rare as shit and the ones you can get are a fair bit , plenty of later zx10r calipers don't suppose they fit? I don't mind having to buy spacers and longer bolts but I don't want to machine anything , options people?
On my 2004 ZX10 the direct replacement for the std calipers were the 2009 ZX6/ZZR1400 Nissin calipers.
So Gen 3 ZX6R calipers should fit.
Quote from: Maddog on November 02, 2016, 12:20:58 AM
problem with that is there rare as fuck , the nissin callipers are very few and far between ive seen sets go for between £150-£250
Quote from: Carbon_ZX6R on November 02, 2016, 01:14:02 AM
they're NOT THERE
Quote from: Green_Ninja on November 02, 2016, 04:40:33 PM
they're NOT THERE
And "rare as Hens teeth"...not "fuck"
I normally frase it as rocking horse shit..
Quote from: Carbon_ZX6R on November 02, 2016, 06:54:18 PM
PHRASE - for fucks sake
Found these
Look at this on eBay http://www.ebay.co.uk/itm/201701075459
Any ideas if they will fit without being machined , spacers are not a problem
You lot are not as helpful as you once was! Well if the credit card gets approved it will be 320mm disks and brembo m4 monoblocs.........
Quote from: Carbon_ZX6R on November 03, 2016, 08:08:28 PM
Discs
Loads of help with grammar.
3rd gen nissins, as you call them, will fit.
Are they the 2010-2013 era ones?
O dear the credit card has just been approved...........
Gen 3 is 09-12
Finding a set in unscored condition is very hard seem few and far between , but I'll find some
what happened with this in the end?
Did you manage to sell the other bike?
Quote from: Andy M on November 11, 2016, 11:37:14 AM
not tried been slower than id like with other commitments it is nearing the end the doner bike is all but back together , its had a good going over with a fair bit replaced (corroded parts)
my bike is almost ready , will be fitting brand new brembo callipers and brand new 320mm discs in the next couple weeks
Well the new calipers and discs are in the post! 😎
april 2017 its first outing?
Pfft will it fuck! , Next week hopefully providing I manage to get some brake lines
Well Christmas came early this year.....
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20161119_190721_zps8lx7v7qs.jpg)
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20161119_190744_zpsu98wuxpb.jpg)
Nice (nothing like overkill on a super sport machine) - are they genuine? Lots of fakes out there :rofl:
Quote from: The Wizard of MOz on November 20, 2016, 09:44:17 AM
Yes there real haha , only slight overkill.....
Just need to try and get some new lines for them
I bet that lot cost lots of £££££££££££££££
Not as much as it should have haha but no wasn't cheap but it's worth it so much else I've done , so why not
Only annoying thing is now I'm working for a massive faceless corporation once again , it's hard to find the time to fit them
£34 for a set of disc bolts!!! When did everything get so bloody expensive!
I'm still not 100% on exactly what you are doing any why
You have 2 B1's and you are making a third out of individual parts you are sourcing online?
I think he said he just needs a tank to finish off bike number 4?!
Quote from: Phil_8 on November 21, 2016, 11:02:29 AM
I have my bike and a donor bike , and I've decided I needed new vrakes for my bike
Quote from: Carbon_ZX6R on November 21, 2016, 12:32:34 PM
Brakes
I was in a meeting I had to rush the reply! Brakes wore shot so decided to replace them , just had a 3 line hel brake line set agreed for £60 delivered o the perks of managing someone's business account!
Quote from: Carbon_ZX6R on November 21, 2016, 06:15:06 PM
were
Well my wallet is now a further £35 lighter!
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20161122_184432_zpso9zrtoar.jpg)
They weigh took all!
Quote from: Carbon_ZX6R on November 22, 2016, 07:15:48 PM
FOOK all
you really are doing it on purpose now aren't you ???
It's the fucking spell check!
Just think how much faster you'll be now......
Home quicker...more time for spelling lessons.
Yes, although light, I dont think paper brake discs will be too effective
cardboard!
Quote from: Carbon_ZX6R on November 22, 2016, 07:30:35 PM
"A bad workman always blames his tools"
:cheesy:
never tried oqwejq brakes. you have to let us know if they are any good
Quote from: LewisBeGoog on November 25, 2016, 10:13:58 AM
Will do mate! 😋
Those counterfeiters seem to get away with anything these days.
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20161127_094210_zpsbiklj0pq.jpg)
Ooooo yes!
Just need new lines now and it's good to go
Those Brembos will last 5 mins if you keep them as mucky as your wheels.....
Quote from: The Wizard of MOz on November 27, 2016, 03:49:47 PM
The wheels are off the donor bike I've not so much as done a miles on it , wheels are normally cleaned regularly
Quote from: Carbon_ZX6R on November 27, 2016, 03:27:56 PM
Ooooo yes!
Spacers look keek...can you colour match with carrier?
Ooooo yes!
How do the brembo callipers fit when removing and installing? I found the spacing between the 320mm disc and the wheel rim pretty tight to get stock callipers on and off the disc.
It's tighter than stock , but didn't really have a problem
New hel lines ordered! Managed to get a good price , tenner more than I was quoted as I wanted black fittings
Did you choose to ignore my spacer comment?
Quote from: Alzo on November 29, 2016, 10:15:29 AM
Sorry didn't notice it , not quite sure what you mean?
The Black spacers between the new Brembo brakes and the original carrier.
I didn't chouse the colour if that's what you mean
No I know that...I'm suggesting they could be colour matched to either the Brembos caliper of the carrier...they ruin a good look.
Ooooo got ya now! I'm being a bit dense, I thought that , the funny thing is there genuine brembo kit so would have thought so
Brake lines arrive , and there not what I ordered I'm sure they will fit fine but I paid for hel lines and they sent there own brand............ Not impressed
There, their, they're.
You're....your...you
Need, knead, kneed.
Supposedly they are hel lines without the hel branding so they are sending out the branding to me...
who, whom, who'd
Fitting new lines is just fitting them doing the bolts up and bleeding them ,right?
Follow the instructions closely...placing any seals/ washers where specified...all take care not to over tighten the bolts.
Quote from: Alzo on December 03, 2016, 05:44:21 PM
Sadly I don't think there are instructions I'll check though I may be wrong
There is usually a diagram of sorts.
On closer inspection there seems to be instructions just hope it all works
If followed and done correctly then there shouldn't be any issues. Bleeding can be a pita...but if you purchase a vacuum kit that sucks the fluid through the system it helps no end.
I'm lucky enough to have one , only got a litre of fluid though just hope that's enough
Should be more than enough...but a quick check of the manual should confirm quantities.
Quote from: Alzo on December 04, 2016, 08:54:54 AM
one problem I may have come across is I have a mini res on the front and an hrc res on the rear.... so will be a pain in the arse...
well its done!!! pain the fucking arse , mother of all airlocks , took it round the block fuck me does the zx6r feel tiny, going to take some getting used to again
Well it got me to work! Feels so strange
(http://i1314.photobucket.com/albums/t574/blackstarracing8/Mobile%20Uploads/IMG_20161205_123437_zpsg5je1zgb.jpg)
Quote from: Carbon_ZX6R on December 05, 2016, 12:36:07 PM
You are not the only one amazed by this!
Quote from: Phil_8 on December 23, 2016, 12:01:58 PM
The fact that I have taken the entire bloody things apart put it back together and it's not killed me , I'm quite amazed
