RR - EVO 3
Started by WizzBang, July 20, 2013, 07:20:55 PM
WizzBang
My order from Honda turned up today
Won't be long now...
Pickled Onion
When youre done can you come and do mine :)
WizzBang
As long as you are footing the bill Iain
WizzBang
Today's installment.....
1.6 Bar rad cap
Motobatt Battery
Latest model Tokico Monoblocks
I like your approach to decision making Neil. I like to think of it as two internal Neil's.... ones the cock and balls and one is the worrier.... we'll call them "Cock and Balls" and "Brain" for the purposes of my imagined internal monologue!
Brain: We have a problem with the bike engine; I can't decide whether to fix it, swap the engine, keep it or sell it.
CAB: We love the bike, we should just fix it!
Brain: We might be able to fix it?
CAB: We can definitely fix it.... we should definitely fix it
Brain: What if we can't fix it?
CAB: We can definitely fix it!
Brain: Should we ask the forum?
CAB: Fine, but mainly so they all know that we are going to fix it, so when we've fixed it, they'll know we've fixed it!
Brain: Humor me, what happens if we don't fix it?
CAB: Look, worst case scenario, we'll fit the engine hoping its fixed and it's not
Brain: What happens then?
CAB: We'll probably lose interest and then either live with a broken engine until it goes pop or eventually sell it anyway
Brain: That sounds like a lot of effort, we like the bike, we don't want to be in that situation
CAB: Fine, we'll just buy a shitload of shinny new parts..... then we're committed!
Brain: I LIKE IT!
WizzBang
actually chuckling in the office here!!
Quote from: Neil on August 06, 2013, 06:54:41 PM
WOW
That is so true it's scary
haha, it's the only way to get things done..... I'm backing CAB all the way!
WizzBang
#39
Today is the turning point in this current work, I've started to put things back together  :)
All cleaned up and ready to go
New gasket
Head back on
Shims and buckets replaced
Camshafts fitted
New seals for the camshaft holders
All timed correctly
Then bolted down
Cam cover on then plugs and leads fitted
Engine back where it belongs
Just have to remember what went where
Should have it all connected and running tomorrow
WizzBang
#40
Quote from: Neil on 09-08-2013 21:05Should have it all connected and running tomorrow
I was right....it was all connected back up and running today
Had it running to gain some heat and all is fine, then once its proper hot I turned it off.....then could hear a sporadic splash as a drip hits the evhaust.....on closer inspection, this is what I have found
Thats the oil cooler gone then
0luke0
WizzBang
Simple...4 bolts, undo, remove and replace.
Trying to find a replacement is a little harder though....new is £400 and bugger all on ebay atm
so do you reckon that was the issue all along?
WizzBang
Well, you only have to look at the symptons......slow water loss, with no leak marks.
Seeing what I found with the head gasket, ie nothing, it has to be something like this.
I'm going to set to it tomorrow with some chemical metal and see if I can bodge it until I can get hold of a replacement.
