Drill the bars, or file the locating dowels?
Filing seems to be the most popular way, but just thought I'd run it by you guys here first.
By that I am assuming minimum of filling so that there is still some friction exerted when tight?
Cheers.
Dave
Drill a hole. It's an education in measuring to get it in the right place but you'll be glad you did.
drill..
i used some electrical tape then center punched it.. then i could check location and makes it easier to drill...
Cheers guys, that's what I'll do.
Was thinking of using tape, but I could maybe make a template from the standard bars, as long as i managed to line it up...
All done! Made paper templates and transferred to gaffa taped bars, centre punched and then drilled.
(http://i140.photobucket.com/albums/r38/hiswitsend/Fazer%20600/fazer/20140420_170525_zpssbijphfx.jpg) (http://s140.photobucket.com/user/hiswitsend/media/Fazer%20600/fazer/20140420_170525_zpssbijphfx.jpg.html)
Cheers for the advice to drill, far better fit :-)
looks good mate
