2009 ZX6R FI light
Started by Chris C, June 19, 2014, 11:16:10 AM
Chris C
Hi Guys
Just wondered if anybody can help me out..
I have just bought a nice 2009 zx6r but it has a issue with the fi light flashing once it's been running for a few minutes and up to temp..
It' starts fine and the temp gauge rises to around 66/68c then starts to go down slightly, shortly followed by the fi light starting to flash? I would have thought normal operating temp would be around the 85/90c range whilst riding? It was also cutting out when coming to a stop with the clutch pulled in, but a idle speed adjusted has fixed this.
Any ideas. Not sure if this would effect it but it is fitted with a PC5, ignition module and dyno jet quick shifter?
I cant get my dash to bring up any fault codes by using the dash readout?
When its on the ODO display and have tried pressing the mode button again for 2 seconds and even tried holding it for 20 seconds.  But the display does not change or bring any faults up.
Thanks Chris
