So this is my trackbike and I want to turn the idle speed up a bit to try and stop it skipping the back wheel about when downshifting. Do I need to adjust the throttle position sensor?
I found feathering the clutch helped more.
Will blipping the throttle help so you kind of match the engine revs?
Leave the throttle position sensor well alone. The idle is adjustable at the engine end of the throttle cable if needed. But it's not a tactic I would employ.
There is an idle adjuster knob above the front sprocket on my b1 iirc
Yeah there is an idle adjuster so changing it is easy. On my k5 fact if I turned the idle up once it went into gear the revs would drop and the throttle position sensor needed to be zero'd. There was a display in dealer mode so you could find the set point. It would knock the powercommander out if the throttle position sensor wasn't correctly zero'd. I will maybe leave it alone and try to learn how to blip the throttle and feather the clutch a bit more. Cheers anyhow all.
If you are barreling into corners at breakneck speed feathering a clutch is the last thing you want to be doing imho...blipping the throttle to match the speed and chosen gear is the way to go.
Does the B1 have a slipper clutch? Maybe leave knocking it down the gears a bit later. I had one and didnt have an issue with it, but i blipped on downshifts
Raising the idle speed to around 2 / 2.5k rpm is a common adjustment for track riding.
Quote from: Alzo on January 26, 2014, 05:38:14 PM
What do you think slipper clutches are doing then?
Quote from: Maddog on January 26, 2014, 05:40:31 PM
No it doesn't. The ZX6RR did but they are rare as.
I'm not 100% sure but Sigma might have started selling slipper clutches for B1/2's?
Yes, but they're £700 plus vat
Quote from: Millhouse on January 26, 2014, 06:00:04 PM
Slipping without any thought or input from the rider thus freeing you concentrate on braking and cornering...to add feathering a clutch in to that mix is asking for trouble in my opinion...and it is only my opinion...I know I would never have done it on road or track...throttle blipping worked for me...I wasn't Rossi on track...but I wasn't a tail end Charlie either.
Only place I've tried it was the back straight at snett, big braking, blipping and the rear was bouncing all over the place.
Add a little hint of clutch slip and all was peachy setting up for the corner.
£840 for a slipper clutch!! The wife generally is ok with any bike related spend, but id have to keep that one quiet! Prob be better off getting a different bike! Think I will try altering what I'm doing first!
Sigma's are £696 inc vat but that's as little as you'll pay for decent slipper clutch - STM's and Suters are nearer a grand.
blipping does not resolve engine braking causing the rear to break traction. Millhouse is right, a moderately manually induced clutch slip is the way to go and very easy to master with a few laps practice. It needs surprisingly little lever action on the clutch.
Try riding a 996 without slipping the clutch to retain stability at corner entry.
Quote from: Millhouse on January 26, 2014, 08:10:16 PM
The right strategy.
Where's the "slaps forehead and feints from shock at getting something right" smiley??
I did say "imho"...and I understand the what clutch slipping does...I have been riding bikes for over 35 years...I just don't have the capacity to concentrate on hard braking...corner entry...then add in a little clutch slipping at the same time...so to that end I tip my hat to both of you for your ability.
Quote from: Alzo on January 30, 2014, 08:55:40 PM
You'd be surprised how natural it becomes it's not that difficult honestly. It's merely about changing a long standing habit (not doing it).
The key thing to riding quickly to to get the basics automated and repeatable. Once I establish a braking, turn in, brake release, power application it's an automated and zero concentration task freeing me tup to concentrate on other bikes, small corrections etc.
If your concentrating hard on the basics something fundamental is afoot ...
Fair comment....I get what you mean in terms of freeing yourself up...perhaps not as daunting as it sounds...I guess a bit of trial and error required to determine how much slip to induce.
Quote from: Alzo on January 30, 2014, 10:10:04 PM
Oddly enough usually a rest on the lever is enough, you don't need to pull it per sell.not sure I'd want to practice it on the road !
No wouldn't try it on the road....I make progress when road riding...but not Track riding pace. Planning a Trackday this year...so will give it a try.
C1h slipper clutch fits with input shaft.
