Once the screws are off etc from the top section, the bottom section which is on the throttle bodies, does that prize off? I was trying to get mine off last night but it's quite tight.
if it's the same as the 05/06 there are clamps round the rubbers that connect to the throttle bodies which need to be loosened plus from memory there was a bolt at the front (I think)
Thanks, I managed to get it off last night by popping the caps off the side of the frame and using an M3 allen key to slacken the clamps.
