Hi Guys
I have a Michelin on the front of my GSXR 750 and need a rear tyres, I would like a tyre that is grippy for Sunday rides and can do a couple of track days even though they will be slow ones (never done a track day before)
I know everyone likes different tyres and it ends up as personal choice, but are there any to make sure I avoid or any I should really try and get?
Thanks, Yodi
I have a k6 750 and use it for weekend blasts and track days. Bridgestone S20's are what I use and love them.
Pilot road 4 get good reviews as do metzler roadtec m5s.
I was thinking of buying a used rear then when they are both worn down change them as a pair, I will check what's on the front for sure and ask again to see what might suit that front.
Thanks
Then put on the same tyre as on the front.
Mixing tyres front and rear is a stupid idea. Especially if you are thinking of tracking it.
If the front tyre is ok then I will if not I'll just change the pair now
If you're going to change the pair then you won't go far wrong with Dunlop Sportsmarts :moto:
That's what I've fitted to the 14 - impressed so far.
Quote from: MOz on March 24, 2014, 10:30:32 PM
+1 for Sportsmarts - 1 point of note though - I find them ever so slightly slower to turn in than S20's so I fitted a 55 section rear instead of a 50 section which fixed this issue well.
One IMPORTANT note on S20's - I found them an excellent tyre in all aspects except wear rate.
2k miles from a rear while the Sportsmarts do 4k miles with no disadvantages.
Thanks for the advice guys,
Looking only on ebay they're £240 delivered. Sportsmarts or the 2 or either??
Im going to my garage in a bit I will check out whats on the front
New Sportsmart 2 is meant be better and cheaper :grin:
£240 is for the 2, then fitting etc, I just did £450 on tyres for my car too :(
free fitting on sportsmart 2 yodi...
http://www.lovedunlop.com/freefittingpromo
I will call my local guys who are on the list but I have a feeling it'll be expensive, Thanks for the link
I had sportsmarts, great when its dry found them a bit twitchy in the wet. I commute all year so wanted the best of both worlds.
I have pilot roads 2ct's on at the month and find them great even in the recent down pours.
Its not recomended to mix tyre makes but it can be done as long as you go for similar compounds. You don't want a touring front and super sticky rear.
I'm sure you get the jist.
What do people think of these options then -
http://www.ebay.co.uk/itm/180-55zr17-120-70zr17-Pirelli-Diablo-Sports-Tyres-Pair-/171269168889?pt=LH_DefaultDomain_3&hash=item27e0701ef9
http://www.ebay.co.uk/itm/New-Dunlop-Qualifier-Front-120-70-ZR17-Rear-180-55-ZR17-Motorcycle-Tyre-Pair-/301140203622?pt=LH_DefaultDomain_3&hash=item461d5ad866
http://www.ebay.co.uk/itm/120-70-17-180-55-17-Michelin-Pilot-Power-2CT-SUZUKI-GSXR600-Motorcycle-Tyres-/351032854564?pt=UK_Motorcycle_Parts_13&hash=item51bb304824
Michelin out of that lot.
My front tyre is a Michelin Pilot Power which has good tread, so now I need to decide do I get a rear to match and just use those or wait and get a new pair.
