Is there a tried and tested method of cutting bodywork? Ive got a race seat for the zx10, its like this
(http://www.carbonin.com/static/motors/parts/SEAT-ZX10-06_1.jpg)
It puts loads of stress on the tank fixings as all of my body weight will be sat on it so i want to cut the seat area away so i can use the standard seat.... like this
(http://www.moto-vision.com/2591-3369-thickbox/race-seat-aprilia-rsv-1000-2004-2008.jpg)
Anyone got any suggestions? Ive seen a few pre cut ones on ebay but are part of a complete set. Im awaiting replies from the sellers to see if they will split
Tis simple......Dremel type tool
Personally I use the Carbon cutting discs, but you can also use the regular ones too.
I went from
(http://i74.photobucket.com/albums/i259/WizzBang00/Bike/RR/RR%20v2/IMG_1257.jpg)
to
(http://i74.photobucket.com/albums/i259/WizzBang00/Bike/RR/RR%20v2/P1010210.jpg)
Using the above method......mark out your cut lines in pencil / chinagraph and trim slow and steady, the discs will slice through the GRP very easily, so you can make a mess if you rush.
Top man!
Why did you do it? The same reason as me?
Why not buy the right set unit to start with ?
There is usually a seat support designed to go under a GRP seat unit (but not a carbon one which are self supporting).
Its cheaper to use what ive got. Ive already got the race seat as in the first pic. It came with used track fairings i brought
