Maintenance & Repair => Mechanical => Topic started by: 636steve on May 04, 2014, 10:08:29 AM
Title: Chain cleaning
Post by: 636steve on May 04, 2014, 10:08:29 AM
OK need to clean all the winter crud and old lube off my chain.
What's the best stuff to use?
Title: Re: Chain cleaning
Post by: Carbon_ZX6R on May 04, 2014, 10:35:49 AM
Quote from: 636steve on May 04, 2014, 10:08:29 AM
Degreaser then use a hard brush on it
Or chain cleaner
Post by: ash on May 04, 2014, 10:39:34 AM
Paraffin and a paint brush.  Cheap and effective.  You don't need to scrub hard, just work it.
Post by: 636steve on May 04, 2014, 10:59:31 AM
Think I've got some paraffin in the shed so will give that a go. :)
Post by: Fastas...... on May 04, 2014, 11:23:41 AM
I always use paraffin and a cheap toothbrush. Up on the paddock stand, a liberal soaking with the paraffin and then brush in. Wash off, I use a garden pressure spray bottle with warm water. Dry off and re-lube. Jobs a goodun  :moto:
Post by: Alzo on May 04, 2014, 07:18:13 PM
No hard rubbing required...does more harm than good. Paraffin with liberal use will do the job...some mild agitation if required.
Post by: 636steve on May 04, 2014, 09:19:05 PM
All done an re-lubed :)
Post by: Carbon_ZX6R on May 04, 2014, 09:33:07 PM
Quote from: 636steve on May 04, 2014, 09:19:05 PM
tingle or cherry?
Post by: Gobert on May 04, 2014, 10:09:32 PM
Quote from: Carbon_ZX6R on May 04, 2014, 10:35:49 AM
Degreaser
Not really the best thing to use.............
Post by: Fastas...... on May 04, 2014, 10:37:36 PM
Quote from: Alzo on May 04, 2014, 07:18:13 PM
That's why I find a toothbrush is good. Gets into all the nooks and crannies. Nice minty freshness too  ;)
Post by: Carbon_ZX6R on May 04, 2014, 10:39:54 PM
Quote from: Gobert on May 04, 2014, 10:09:32 PM
Degreaser
ive always used it gets all the road shit off
Post by: Gobert on May 04, 2014, 10:46:24 PM
It's not recommended because it can effect the rubber O / X rings. Makes them swell?
Post by: Carbon_ZX6R on May 04, 2014, 10:57:02 PM
Quote from: Gobert on May 04, 2014, 10:46:24 PM
it does depend on the chain I forgot to mention that but ive always used it then just put the chain lube on
Post by: ash on May 05, 2014, 12:23:05 AM
Most degreasers are mineral oil based (as is paraffin)  and so is most chain lube and so is the grease within each link, so if the expansion is part of the o rings working environment, everything around it will have been toleranced to allow for this. The greatest problem with o ring chains is allowing them to dry as this massively increases the wear on the o ring. The other issue is grit sticking to the lube and making good grinding paste,  and lastly rough handling  risking damage to the o rings when cleaning.
Useful info about  o ring chains, and why they need to be kept wet  ...
http://www.loobman.co.uk/faqs.asp (http://www.loobman.co.uk/faqs.asp)
Post by: big gav on May 05, 2014, 10:14:44 AM
Best thing about using paraffin is that its a seaking agent. i.e it will find its way into to smallest of gaps . Consequently when you lube the chain after using paraffin the lube will follow the path the paraffin took.
