Hi
My bike was fine a week ago and it's been parked up since then outside with a cover on.
This morning when I strated it up the FI light came on and stayed on all the time but the bike seems to be running fine.
Any ideas?
It's a 2003 Kawasaki ZX6R 636 B1H.
mine came on once on the b1h when it was bloody cold ran it warmed it up and the light went off
There's a lead you can short to Earth on the loom and it will give you the error code
Quote from: 0luke0 on November 17, 2014, 09:28:59 AM
Self diagnosis terminal! As you look at the back of the bike you will find it to the RHS of the battery tucked in beside the terminal. Ignition on, ground the lead and wait for the FI light to flash a sequence of long and short duration flashes. Note it down then post it back and the manual gives a code table to tell what the code refers to.
Thanks. The fault code was for air flow sensor but it as the wire that was broken rather than the sensor so all fixed now.
Quote from: IA76 on March 23, 2015, 08:45:00 AM
took you long enough!!
Result :)
