Hi.
I have a 2002 636A1p and have heard the horror stories about replacing a snapped front indicator (Hours of work).
Being useless, I have a plan to fit flush front indicators and glue them into place. Anyone recommend any that fit as I'm struggling to find some.
Regards.
Any "Kawasaki" fitment should be fine I used motrax
Quote from: Carbon_ZX6R on April 27, 2015, 06:50:15 PM
Thanks for the quick reply...........
Is my glue plan viable?
These...
http://www.ebay.co.uk/itm/MOTRAX-LED-FAIRING-INDICATOR-WINKER-LIGHTS-Kawasaki-LFK1-/111512229101?pt=LH_DefaultDomain_3&hash=item19f6a594ed
The hardest bit is removing the fairing lower which is about half a dozen hex head screws. The indicator is about 10 minutes once you get to it.
Quote from: copthis1 on April 27, 2015, 06:59:18 PM
These...
Yep them , not with those ones its not but I cant see why you would need to
I've read that the job is a mare and takes 2-3 hrs..... allowing for my crapness with a spanner, a month :cool:
Quote from: copthis1 on April 27, 2015, 07:51:57 PM
I cant possible think of any possible way it could take anything like that unless every single bolt has to be drilled out and you then have to drive 20 miles for replacements? , alot of it is common sense it wont take anything like that
I had an A1p and did a fair few trackdays on it and removed the indicators each time. I can't remember if you had to take the top fairing off but it's a doddle and could be done in 30 minutes
in original form they have a retaining plate on the inside which can get stuck, however the indicators stay in fine without then so fitting the indicators is just a case of feeding the wires through the hole and then pushing the rubber supporting arm into the holes so that it fits flush against the lip on it, I find a small flat blade screwdriver helps here. My ZX6RG never had the retaining plates and neither does my ZX9R on which the indicators are incidental.
Oh yes and the flush fit ones look gash.
I only fitted flush ones because I swapped to mirror indicators.
You doing the rear aswell , remember these are led, and your either need a new relay or inline resisters but ive heard bad things about the latter
Quote from: Green_Ninja link=topic=2backplate0538#msg30538 date=1430170709
If the indicators stay in without the backplate, I'll do that......
Thanks for all replies.
your welcome , let us know if you run into trouble
Quote from: Carbon_ZX6R on April 28, 2015, 07:24:58 AM
Yes, any mechanical trouble be sure to ask Carbon for his advice........
Quote from: Tiiimmmaaayyyy on April 28, 2015, 08:19:24 AM
im a font of knowledge thank you very much!! most of it may be useless but there is some good stuff in there!
Quote from: Carbon_ZX6R on April 28, 2015, 08:24:20 AM
really ;) can you prove that
Quote from: Green_Ninja on April 28, 2015, 09:29:05 AM
(http://i2.kym-cdn.com/photos/images/facebook/000/065/003/Darth-Vader-I-FIND-YOUR-LACK-OF-FAITH-DISTURBING.jpg)
Quote from: Green_Ninja on April 27, 2015, 10:38:29 PM
Super advice....merci.
Quote from: copthis1 on May 18, 2015, 07:34:34 PM
you got them yet?
