Maintenance & Repair => Suspension => Topic started by: Carbon_ZX6R on August 20, 2016, 07:21:58 AM
Title: fork internal swop is it possible
Post by: Carbon_ZX6R on August 20, 2016, 07:21:58 AM
right on my doner bike the forks have K-Tech 20SSK Piston kit and Flow Control Valves fitted so this is obviously a big step up over stock I was going to just switch the forks out but mine are in much better condition , on the ketch spec forks there is pitting on the fork bottoms and also some light pitting on the stanchions , and what looks like a dodgy seal (not gone yet...)
how realistic is it to just switch the internals over to my set of forks , is this even possible , what would I need etc?
Title: Re: fork internal swop is it possible
Post by: David W on August 20, 2016, 10:41:38 AM
You'd need to get K-Tech to do it or you'll probably fuck it right up.
Hope this helps.
Post by: Carbon_ZX6R on August 20, 2016, 11:06:28 AM
Quote from: David W on August 20, 2016, 10:41:38 AM
Hope this helps.
is it that complicated then?
Post by: David W on August 20, 2016, 11:13:23 AM
Its having the right tools to get the internals out of the fork legs and holding it all in place while you fit them in the other legs.  Its not the sort of thing you want to screw up.
Post by: Carbon_ZX6R on August 20, 2016, 11:17:09 AM
Quote from: David W on August 20, 2016, 11:13:23 AM
ahh I understand is switching the fork bottoms round any easier  or is it the same boat?
this bit
(http://www.racetech.com/images/G6Forks/FB_GSXR_2_600.jpg)
Post by: David W on August 21, 2016, 09:32:26 AM
Never done.  Are they pressed onto the fork tubes?  Not something I'd want to risk being done wrong personally.
Post by: Carbon_ZX6R on August 21, 2016, 09:51:15 AM
Quote from: David W on August 21, 2016, 09:32:26 AM
Well if the pitting rubs off the stanchions I'll just swop them out as that's the most important bit ,everything else can be anodised polished or painted I guess and a fork seals not the end of the world , I'd imagine that's something that can be don't my self?
Post by: greenmeeny on August 21, 2016, 05:35:40 PM
On t web a guy shows how to make diy tools for this very job. Haven't got a link.
Post by: Carbon_ZX6R on August 21, 2016, 05:38:02 PM
Of switching the internals?
Post by: Green_Ninja on August 21, 2016, 05:42:32 PM
Quote from: Carbon_ZX6R on August 21, 2016, 09:51:15 AM
I seem to remember saying something along these lines before but here I go.
If you need to ask these kind of questions about important bits like suspension/brakes/wheels i.e. the things that will keep you alive when the smelly stuff hits the fan you shouldn't be considering doing it yourself.
Also instead of asking on here research the job properly.
Now I'm not saying you aren't capable of doing the job BUT as you ask on here and the questions you ask you don't know where to start.
In answer to the question - Yes of course the internals can be swapped over - however you will need a number of special tools for the job. Right way up forks are relatively easy I have done a couple of sets. I wouldn't try with USD forks due to the tools required it will probably cost more for the correct tools to do the forks than paying a suspension specialist to do the job properly.
I am pretty sure that the forks bottoms on the B1 forks cannot be successfully removed and replaced and the way to go is a new set of stanchions.
Just my opinion, feel free to ignore it like all the other advice you ask for ;-)
Post by: Carbon_ZX6R on August 21, 2016, 09:01:41 PM
I've done rwu forks before so wasn't sure how different it would be , it should still be relatively easy to replace the seals on the forks yes?
Post by: David W on August 22, 2016, 07:05:55 AM
Everything is easy when you know how to do it.
Unlike RWU forks, you need to strip and seperate the fork legs.  Something you don't know how to do.
I'd class myself as reasonably confident at replacing things and most maintenance tasks on a bike but I'd class that particulatly job as one for the pros.  The consequences of screwing it up are too high for me personally.
Post by: Carbon_ZX6R on August 22, 2016, 07:18:20 AM
Quote from: David W on August 22, 2016, 07:05:55 AM
puts it in perspective a bit
Post by: Carbon_ZX6R on August 22, 2016, 07:35:17 AM
just watched a video of it being done on youtube , looks quite easy if I'm honest (on generic fork used) but with the ktec bits I feel I might run into problems so I think I best leave it alone as I don't want to bugger them up , was tempted to leave my stock forks on but I suppose these are a worth while upgrade
Post by: David W on August 22, 2016, 10:33:00 AM
Have you asked K-Tech how much they'd charge to swap them over?  You might be surprised how reasonable they are if you take the forks to them.
Post by: Carbon_ZX6R on August 22, 2016, 10:39:05 AM
Quote from: David W on August 22, 2016, 10:33:00 AM
I think I might send them an e-mail might be all but the same as new fork seals
Post by: Carbon_ZX6R on August 22, 2016, 10:46:59 AM
Email sent!
Post by: Lord Danoir the first on August 22, 2016, 02:39:16 PM
I've just bought new forks for my MV. As I've no idea of their history, Maxton are giving them a going over for £150.
Not worth messing about for the price of a decent meal out.
Post by: Dom1 on August 22, 2016, 02:44:17 PM
Quote from: Lord Danoir the first on August 22, 2016, 02:39:16 PM
Blimey KFC have really put their prices up.
Post by: Carbon_ZX6R on August 22, 2016, 04:28:54 PM
Hm racing have said 120 + parts and vat and depending on what I want done with the other forks , might just switch the forks and have them tidied up in the future
Post by: Lord Danoir the first on August 22, 2016, 07:53:18 PM
Quote from: Dom1 on August 22, 2016, 02:44:17 PM
Made me Laff did that....... Man I looooove KFC
Post by: Dom1 on August 22, 2016, 09:29:02 PM
Shouldn't have mentioned them, I want food that comes in a bucket now.
Post by: Carbon_ZX6R on September 10, 2016, 05:40:06 PM
Going to just switch the forks and later down the line have them returned , right as the ones on the donor forks are marked up  what is involved in removing the fork caps as there are adjusters I imagine they don't just come off?
Post by: Lord Danoir the first on September 10, 2016, 06:33:53 PM
http://www.kawiforums.com/how-tos-faqs/184673-how-dismantle-inverted-forks-pic-heavy.html
Post by: Carbon_ZX6R on September 10, 2016, 07:04:12 PM
THANK YOU!!!!!!!!!!!!!!!
shouldn't be any different because of the piston kit?
Post by: 1-600-matt on September 11, 2016, 01:37:40 AM
Quote from: Carbon_ZX6R on September 10, 2016, 07:04:12 PM
No. The fork cap will be as per stock. You still need to compress the spring to get the cap nut off.  The k-tech kit will be mostly in the guts of the cartridge. Swapping the cartridge of the forks over would be simple to do if you know how to strip and service USD forks. I would recommend you send them for a service and have the internals swapped. The slider bushes will likely be due a change and doing them isn't easy on the b1 if you don't have the correct size drivers.
Post by: Carbon_ZX6R on September 11, 2016, 06:03:34 AM
Quote from: 1-600-matt on September 11, 2016, 01:37:40 AM
Well that rules that out just don't have the space and tools anymore , pooh don't say that I've only just decided not to swap the internals and now I'm considering it again , the plan was to swap the forks and when the seal goes have them fully stripped and refurbed , sleeves anodised black stanchions with dlc coating fork lowers black again and was going to try and get a set of these afterarjey fork caps as the b1h are a bit boring but not sure what size would be needed
