Maintenance & Repair => Mechanical => Topic started by: Millhouse on October 15, 2013, 03:13:26 PM
Title: chain splitter/rivetter?
Post by: Millhouse on October 15, 2013, 03:13:26 PM
any recommendations for a chan splitter/riveting tool?
where from?
how much?
Title: Re: chain splitter/rivetter?
Post by: Bullet on October 15, 2013, 03:36:30 PM
I got one like this:  http://www.ebay.co.uk/itm/Motorbike-X-Ring-Chain-Cut-Rivet-Workshop-Tool-/360212192686?pt=UK_Motorcycle_Parts&hash=item53de51ddae
accept it was only about £30 from 'bits-for-bikes' or something (cant find it now!) and it joined chains just fine, splitting chains however it snapped the bit in the tool really easily unless you ground the head off the chain pin first and replacement bits were £7 each.....
never tried a differant sort, but id say theres got to be ones out there that dont need you to grind the chain first before splitting!
edit: found it, it was one of these..... http://www.bitzforbikes.co.uk/Chain_Cutter_And_Riveting_Tool.-ref-2744-50.html
Post by: big gav on October 15, 2013, 06:04:15 PM
Grinder = splitter
2 ball pein hammers = riveter
Post by: Green_Ninja on October 15, 2013, 06:24:02 PM
you should always grind the head off the pins before pushing them out not doing is why you break the tool.
Post by: Bullet on October 16, 2013, 09:16:49 AM
whats the point of a splitter tool if you need a grinder for it to work. mayaswell just cut it off with the grinder like big gav says!
Post by: Ant on February 18, 2014, 07:15:56 AM
I've been thinking about the same thing. I've got to get my chain off completely and wondered about this.
Post by: m6rk on February 18, 2014, 10:07:45 AM
never bothered with a splitter.. I swear by the hollow link DID chains. Use the DID (or a copy) chain tool and it's foolproof to make a nice neat link and not overtighten it..
Post by: Gobert on February 18, 2014, 10:10:52 AM
Quote from: m6rk on February 18, 2014, 10:07:45 AM
+1 - I bought a DID copy tool and there are details on the DID website specifying exactly how far to flare the soft links.
