Quick action throttle
Started by Maddog, October 06, 2013, 04:27:25 PM
Can anyone suggest a quick action throttle kit for my ZX10 2004/05?
One love
Doug_Z1000
I just used the rifleman insert on my old Gen 2 ZX10R, a bit of a Dremel needed on the housing but an easy fit and worked brilliantly for the price.  I have an Active q/a throttle on the ZX6R, it comes with a choice of throttle tubes so you can find a ratio you are happy with.  It's so good I've just bought another kit for my Z1000.
Cheers for the reply mate
Is it obvious what needed to be cut?
Quote from: Maddog on October 06, 2013, 04:27:25 PM
One love
Active8, Venhill, Kawasaki Kit
Used both without issue...
The rifleman insert....from reading some forums, needs some cutting of the adjusters at both ends.....is this a problem you had?
Doug_Z1000
I used the oem cables, but had to snip the two lock nuts off the adjusters in the middle of the cable.  Inside the throttle housing there's ridge, that fouls the tube when the insert is added, it just needs shaving down a bit.
