c1h to pf8 brake disc compatability
Started by k-factor, October 07, 2013, 03:45:41 PM
k-factor
just wondering if anyone could confirm if the front brake discs from a C1h are the same and would fit my p8f.
mine are done and theres a set of c1 front discs on ebay that seem good.
when i check online on the microfische the part numbers are the same (41080), only difference i can see visually is the colour of the hubs. http://www.cornwallkawasaki.co.uk/shop/shop.php?cmd=showdiagram&id=439.
thanks for reading, hope someone has the answer.
greenmeeny
Doug_Z1000
I've got ZX10R D7F discs on my 636 C1H, as long as they are 300mm most Kawasaki stuff seems a straight swap.  I did have ZX14 310mm discs on, with 5mm spacers for the calipers, they were a straight fit as well.
