Any tips for removing cylinder head studs - zx10r
Started by Martin#30, September 01, 2014, 09:34:45 PM
Martin#30
Evening all,
I need to remove the cylinder head on my 06 10R, and I am struggling to loosen the bolts holding the cylinder head to the block.
I have removed all of the cams, chain guide, crank sensor etc. as detailed in the workshop manual, but I simply cannot loosen the studs themselves. It feels like I am likely to round the stud heads before they start to loosen.
Any tips? All I can think of is to physically remove the engine so I have enough room to get an air impact gun onto the studs, and try and shock them off. That is a fair bit extra work though, so would like to avoid if I can.
Thanks all,
Martin.
Wiltshire based, bit of a trackday addict, ex racer with North Glos, commuting on a 1400GTR and riding round in circles on a wheelbarrow ZX10R.
Tighen them a nip before slackening them off. Go buy a decent socket if you are unsure about what you already have
Martin#30
Thanks Ash. This worked a treat, and I managed to get the cylinder head off tonight.
Now to see if I can bolt it all back together, and start it without metal on metal carnage.
Martin.
