ZX10R Brake Caliper, M/C Setup
Started by comment, November 09, 2015, 06:09:49 PM
comment
This was fitted to a 2004 model and selling as I'm using my road ZX10R as the basis for a university project. Includes...
Triumph Daytona 675 Nissin monobloc calipers (108mm bolt spacing).
HEL braided lines.
BMW S1000RR Nissin radial M/C and pot.
Banjo pressure switch.
Racebolt stainless steel pre drilled bolts.
The calipers have had material removed from the posts to suit and even then are NOT suitable for 300mm discs. You require 310mm or larger (with spacers).
£300 including P+P.
