exhaust
Started by vro551, September 05, 2013, 05:50:59 PM
vro551
Can anyone tell me if the other titanium sleeves of an akrapovic can, can be removed completely and changed with carbon fibre.
Thanks
Evil636
If its the oval titanium then it will be manufactured the same as the carbon so it should be as simple as drill out the rivets and then seperate and re-rivet together so I would say defo yes on that one.
vro551
Its the newer shape, tri oval, guess its the same construction method, or am I wrong
Evil636
Thy are all pretty much the same. Drill rivets out, persuade the mess off and it will come away. Do why you want with it then put it back together and rivet it back up.
vro551
