'08 6R coolant flange
Started by Ant, February 19, 2014, 10:31:38 PM
Ant
Flange, oo eeerr mrs.
In the photo, there's a coolant flange, I want to possibly remove it to release the rest of the coolant from the engine before removing the engine. Shall I remove this and let it all out or is there a better way? What's under this, a stat? Or just an entry into the engine coolant veins? Thanks.
DaveH
Is the water pump and I'm guessing that one of the lower two bolts is a drain bolt... assuming they've not gone radically different in the newer stuff.
DaveH
#3
I'll guess at the one on the right of the two... or left ;-)
Ant
Thanks Dave, I'll give one of those a go and see if it's the drain.
