THE GREAT B1H RESURECTION!!!
Started by Carbon_ZX6R, April 17, 2016, 07:16:07 AM
Quote from: Green_Ninja on July 27, 2016, 09:40:10 PM
May as well put the oil and filter in to be honest one less thing to forget to do later  ;)
Was just making sure it wouldn't cause problems by me not warming it up etc and properly doing it etc
Don't like the idea of it being dry , the tanks a big enough problem , I don't fancy stripping the engine
Put the oil in...pull the spark plugs out...put the bike in fourth gear....push it for 1000 yards with the clutch out...then push it 1000 yards back...that will have built up the oil pressure and circulated it nicely.
Quote from: Alzo on July 27, 2016, 09:50:31 PM
Good idea that Alzo  :azn:
Quote from: Green_Ninja on July 27, 2016, 10:18:12 PM
I thought so.  :azn:
#109
I almost took that seriously
Quote from: Carbon_ZX6R on July 28, 2016, 06:34:44 AM
I almost took that seriouslu
And so you should.
Question is do I just put the new new filter on and dump the full 3.6l in or what as I can't start it so getting it to the correct level is easier said than done
Tiiimmmaaayyyy
Quote from: Carbon_ZX6R on July 28, 2016, 07:52:44 AM
Pop the filter on, fill the oil to the upper mark, run the engine and then re-check the level. Some people put some oil in the filter before installing it but I've never bothered. Nothing has blown up yet.
My problem was I can't start the engine....
Stick 3 litres in...turn the engine with plugs pulled to circulate...and when you are ready to fire up for real run until warm...cool it...top up as necessary.
Quote from: Alzo on July 28, 2016, 08:22:58 AM
so pull the spark plugs stick it in gear and push it?
I meant hook up a battery and turn it over using the Starter motor. All depends on how long you intend to let the bike sit before you're ready to run it again.
Quote from: Alzo on July 28, 2016, 09:18:36 AM
ahh I intend on it sitting there the least amount of time possible just need to tackle tank and pump as I cant put them on with rust , battery is connected, is the removal of the spark plugs essential?
Tiiimmmaaayyyy
Fill it with oil and then rock it from side to side for an hour to get it around the engine
terry950sm
Quote from: Tiiimmmaaayyyy on July 28, 2016, 09:46:26 AM
Dont forget to shake it all about :cool:
Growing old gracefully
