specialized rockhopper comp m4
Started by iggy rs, November 05, 2013, 09:06:14 PM
iggy rs
bought from evans, Only been used a handfull of times, still has some of the protective film on the on the frame, its a 17" frame, has lock out front shocks, the spec is below from evans website, I think I have used it 3 times this year, so it might as well go to someone who will use it how it is supposed to be used.
can be collected from kent, dartford or if I am passing in the lorry where you live I will deliver.
Frame:
M4 manipulated alloy frame with a butted ORE downtube and forged dropouts with a replaceable alloy hanger. Disc only.
Fork:
RockShox Recon Race Slite with 100mm of travel. 32mm stanchions and steerer. Turn key damper with lock out and rebound adjust. 15" standard spring, 17-27" stiff spring. Disc only.
Front Derailleur:
Shimano Deore FD-M530 with a 34.9mm clamp.
Rear Derailleur:
Shimano XT RD-M771 SGS cage.
Shifters:
Shimano Deore SL-M530 trigger.
Chainset:
Shimano FC-M521 Hollowtech. Replaceable rings with alloy outer and Octalink spline.
Chainrings:
44/32/22 teeth.
Bottom Bracket:
Shimano BB-ES25 Octalink spline. Cartridge bearing. 68×118mm for 50mm chainline.
Cassette:
Shimano HG-50 9 speed with a 11-34 tooth range.
Chain:
KMC X9 with reusable missing link.
Pedals:
Shimano 505 SPD with reflectors and cleats.
Front Brake:
Avid Juicy 3 SL hydraulic disc brake with 6" G2 clean sweep rotor.
Rear Brake:
Brake Levers:
Avid Juicy 3 SL hydraulic disc levers.
Handlebars:
Specialized alloy butted 31.8mm XC rise bar with graphics. 640mm wide with a 8 degree back and 8 degree up sweep.
Stem:
Specialized four bolt 3D forged alloy. 31.8mm with a 7 degree rise.
Headset:
1 1/8" threadless.
Grips:
Specialized Enduro dual density Kraton grips.
Rims:
DT Swiss 445D double wall disc rims with pin joint and eyelets.
Front Hub:
Specialized Cartridge Hi Lo disc 28 hole hub with CNC flanges and disc mount. Sealed cartridge bearing and a alloy quick release.
Rear Hub:
Specialized Hi Lo disc cassette 32 hole hub with CNC flanges and disc mount. Polished races and a alloy quick release.
Spokes:
1.8mm 15g stainless with alloy nipples.
Front Tyre:
Specialized Fast Track LK Sport. 26×2.0″, 60 TPI, wire bead.
Rear Tyre:
Tubes:
Specialized Schrader valve.
Saddle:
Specialized Indie XC Sport with Kevlar sides and Cr-Mo rails. 143mm width.
Seatpost:
Specialized butted alloy two bolt micro adjust head. 30.9mm.
Seat Binder:
Specialized alloy with quick release and brass washer.
Accessories:
Chain stay protector, reflectors, clear coat.
https://www.dropbox.com/sc/hkztv2svikwkhw1/3o7TEjvJeN
https://www.dropbox.com/sc/eq9vte621f775yx/L587A88_4S
£300 ono
photos are done on my phone, I will re do them when I find the camera
Manic636
Will ask the other half tomorrow as she wants a rockhopper and would pinch mine if it wasn't too big for her, will confirm sometime in the pm if no-one else has it before..
Also interested here, just not sure if it is big enough for me.
Will try and pop into Halfords and try one.
dannyboy
Oh nice bike!!
Sizing wise:
M (16-18in): Generally for riders between 5ft 7in and 5ft 10in
WizzBang
I'd say that would be a great fit for you Dom....it's better for the frame to be undersized rather than oversized as you can fine tube with longer stem, seat post etc
Chojin
Manic636
Go for it Dom, looks like timing not right for Katie's budget and I can wholeheartedly recommend the Rockhoppers...
iggy rs
i'm 5.9, and the seat is not fully extended, I tried a bigger frame and it just didnt feel right, this is a great bike, very very light, but I just dont use it.
the wife might be selling hers soon, but she using it till just before we go away, hers is a scott, bought from evans.
komp
ivan
if dom doesn't have it , give me a shout.
cheers
k
KTM 1290 Superduke GT
BMW R nine T
iggy rs
its got dom's name on it now, just need to sort out getting it there.
Nice one Dom, I've just got the Rockhoppers uglier, less classy sister and I love it!
