08' engine bolts
Started by Ant, March 05, 2014, 08:36:40 PM
Ant
Hi, can someone show me a photo of their engine bolts on a 07 to 08 ZX6R? I've got the R&G crash bobbins on there at the moment and I want to put it back to standard. So at the moment I'm not sure of the bolt length, whether or not it's a hex head and what fittings should be on there. Thanks.
Ant
Thanks Gav.
On the diagram, part 92151, is that meant to touch the engine or just be a few mm apart from the engine do you know?
Why are you taking the R&G's off?
part 92151 should be touching the engine and even torqueq if i recall.
Yes it should be touching as Jonesy says
Ant
