Brake disc rust removal
Started by Carbon_ZX6R, December 11, 2016, 10:05:06 AM
Chojin
The one which leaves a PTFE coating - Stops that rust from coming back a treat.
Chojin
Quote from: Carbon_ZX6R on December 11, 2016, 08:57:00 PM
Ah so not normal gt85.......
Haaaaaaaaang on a minute -  is this....
... is this a double bluff?
Quote from: Chojin on December 11, 2016, 09:55:54 PM
That's what it says in my can
PTFE is pretty slippy...would I put slippy stuff near my brakes I ask myself...the answer would be "?"
I'm going to end up fucking my brakes at this rate listening to the wrong person...
Just nip down to Halfords and ask for some Brake Disc Lubricant.  Job done.
Quote from: Carbon_ZX6R on December 12, 2016, 06:14:55 AM
I've already gave you the answer.
the invisible dog
Surely?  :rolleyes:
Fixes everything!
*other water dispersing agents with numbers in the name may be available
the invisible dog
the invisible dog
the invisible dog
Or you could go old skool Brando....
Slacken off your bleed nipples half a turn. Get some correct size plastic piping and fix that to the bleed nipples , the other end should go to the affected areas. So each time you brake you will be lubricating the rusty areas. Keep checking your brake fluid level on a weekly basis . Or adapt the brake fluid bottle to replace the reservoir.  :moto: :moto:
Once it's clean hook up a Scotoiler to keep it lubricated alongside the chain.
Remember the oil reservoir will depleat twice as fast as normal.
